Originally Posted by cre
Is the gas fresh?
what cre says is very important... which is why i asked if the car has been sitting for awhile. gas sitting in any vehicle have a tendency to "gunk" up. clogging everything. and will also project the symptom you are having.
Edit: btw, they make these starter fluids that you can use to spray into the air filter or spark plugs to help with the ignition.
this might tell you whether or not it is fuel related? honestly, i've never used it on a car, but used it on an old motorcycle i had... helped me distinguish a problem (needed carbs to be cleaned). but then again, maybe you shouldn't use it to avoid harming the car further before you're able to take it somewhere for a more thorough testing.
