Originally Posted by ItsOthatOguy
Ok new problem. I just changed the fuel pump and put in a new relay. The car would start but not run long. And now won't start at all
What do I do? Has anyone heard of this problem?
Hi! Questions? If the car was bought from a used car dealer , was there a warranty you could call on? , How long is " not long " ? -seconds ? minutes ? ? How does the engine die ? ,slowly ( fuel starvation ) ? Quickly ( spark stop ) ? misfire ? Start and stop ? , the more symptoms info you can supply to give a bigger picture , the quicker the answer can be found . Have you checked the fuel filter ? is the loom connected to the mass air filter ? .
