Old 12-05-2012, 10:40 PM   #29
ccguy
ccguy is on a distinguished road
coil packs made it a little better but still heavy stumble.
if the ground going from the metal coil pack bracket is not hooked up it runs just the same. then if i ground it, it still acts the same. i think i remember reading if it does not have a good ground it will not run right. so what am i missing????
i am testing the plug wires for a grounding crack issue now.
1980 toyota 4x4 truck
1987 7mgte motor, 3" exhaust, water to air intercooler.
4.88s locked, dual cases, lift.....
ccguy is offline   Reply With Quote
