There is not plug and play aftermarket EMS for the GE to you're options are: pick a full EMS and rewire/replace sensors as needed; Swap completely over to GTE electronics and all a fuel controller and manually tweak timing; Use a MAFT Pro piggyback in combination with either the GTE or GE electronics to control boost, fuel and timing. My recommendation would be to at least swap in GTE electronics.
