Old 12-16-2012, 03:03 PM   #144
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
Im going to buy a set of oem coils and connectors just have to save up some money.Just to be safe what is the best way to get even beter spark what is the best ignition booster to use because i'm using E96 fuel that needs beter spark.
1) With oem 2jz-gte brand-new coils and the correct spark plugs, you could probably set diesel fuel on fire. The 2jz-gte's oem ignition system has proven itself to well over 850hp, with no issues whatsoever. You might want to give this setup a try before you put any money into an ignition amplifier.
2) If you're absolutely convinced you need an ignition amplifier, the HKS DLI-2 Twin Power Ignition is a proven choice. Here's one place you can purchase it:
http://www.mvpmotorsports.com/Templa...207&SearchYN=N
Life begins at 30psi.
