Old 12-16-2012, 07:35 PM   #148
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
So you still think it is the connectors that is causing the miss but why was it okay on the dyno.
i'll appreciate the part number.
The street puts more load on the engine, which in turn generates more heat. More vibration could be a factor too. Either way, with new coilpack connectors and new coils I'd bet you'll be fine.
http://mkiv.com/techarticles/parts/c...ess/index.html
90980-11246 Coil Pack Connector
82998-12440 Repair Terminal
http://www.suprastore.com/tosucopaco19.html
Name:	Coil Connector Housings.jpg
Life begins at 30psi.
