every thig you need drift otion now has the new oil cooler and ps cooler and the oil fileter adapter that will let you run a direct system (or the smart way like cre says whith a thermostat)
http://store.driftmotion.com/static/i-bpm-202-28.php oil filter adapter
http://store.driftmotion.com/static/i-psoilcooler.php ps cooler
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
