Old 01-09-2013, 02:16 AM   #18
bigdame67
bigdame67 is on a distinguished road
If the code says TPS, I'd start by swapping out the TPS. Be careful though - it needs to be adjusted perfectly in order for everything to run right. The screws holding the TPS in use Loctite for a reason.
Best case you can find a used TPS from another Supra that you can use as a test. Also, check the harness with a multimeter.
I had a problem with my TPS once because some moisture got into it.
All these troubleshooting steps are in the TSRM - you need to get one because the Mkiv Supra is too rare for your local dealership to keep one on the shelf.
Thank you for your feedback
bigdame67 is offline   Reply With Quote
