Originally Posted by warmkop
Phoned toyota today they say the part nr you gave me for the terminal repair does not exist are you sure that is the right nr.
I bought a 1jzgte enjin for other conversion i want to start as soon as the supra is fixed,anyway i swop its coils with mine it still had the same miss i'm first going to get new connectors to see if it is not the connectors.
Have you ever heard of a supra having problems with its ecu or crank pick up just wondering.
That may be a Lexus part number - please check if your dealer can find it under Lexus.
Yes, the metal 'tooth' plate on the crankshaft can come loose, and/or the magnetic pick-up sensor (or its harness) can be faulty. The troubleshooting steps in the TSRM go through diagnosing and correcting any of these possible issues.
