Before you go pulling the big stuff apart check that the slave cylinder is moving far enough, the clutch master cylinder's reservoir is full, and that the fork isn't bent. Flushing the transmission fluid may also aid in the ease of shifting but the impact on shifting into reverse is seldom significant... worth a try though.
