Originally Posted by DSMeATER
okay, so I put in a new throttle positioning sensor today (what a pain in the ass that was) thinking that would solve all my problems...but it was really on the contrary now when the car did fire it had a high followed by a bouncing idle ... now it wont fire any ideas on what could be causing this issue?
Did you adjust the tps when you installed it? If not that may be your problem, also possibly vacuum leak based off the bouncing throttle. Maybe a stuck IACV.
Start with adjusting the TPS per TSRM.
What was the problem you were trying to solve to begin with??
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
