Originally Posted by Sonyps307
There's supras running 1000+hp on stock internals on pump gas all day
Prove it. Name even ONE Mkiv Supra Turbo that has this setup right now, and I'll personal get in touch with him/her to verify. If you won't or can't then please STFU because this is VERY BAD advice. Will you buy Mmeyer183 his new engine when he trys this and his #6 cylinder starts blowing large, dense clouds of bluish white smoke out his tailpipe?
Where are you getting this *bad* information? Please let me know so that I can set him/her straight too. Let me set you straight: There is no 3L 2jz-gte Supra on earth pushing 1000hp with only 93 (R+M)/2 octane fuel. Period.
Without water/meth injection, 1000hp on pump gas using a 3L 2jz-gte is
completely impracticable. With an unlimited budget and no care for power:weight ratio, sure it's theoretically
possible...for example, you could try rig up a system that cools the charge-air with liquid nitrogen. If you got the intake air cold enough (I'd guess the air would need to be maintained at about -150 degrees F during full boost), you *might* avoid detonation with 1000hp and pump gas using a 3L 2jz-GTE. Oh, don't forget that at -150 degrees F, the air (and therefore intake O2) would be MUCH more dense, so the air-fuel mix would need to be tuned appropriately to compensate.
Mmeyer183, if you're not on an unlimited budget, and/or you don't want to waste months experimenting and replacing expensive engine parts, make it easy on yourself and simply ignore Sonyps307's post.
