Old 02-23-2013, 12:22 AM   #162
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
The spring is 1.5 bar going to put a 2 bar spring and set the boost down.
just tested the car with the 225 battling to get rims for the MT slicks.
must get the 1/4 mile times down.
Need a decent boost controller at the moment it is a manual boost controller.
I agree changing the wastegate spring will likely help with the fluctuation issue. Also ensure your blow-off valve(s) have sufficient volume to bleed off any compressor surge if/when necessary.
Regarding the tires...again, 225 seems far too narrow. You need to be running at least 12" (305mm) wide tires on at least 11" (280mm) wide rims, with very low tire pressure, and purpose-built drag race rubber (either drag radials or slicks) in order to get good 1/4 mile results from your new horsepower levels.
Life begins at 30psi.
