Old 03-03-2013, 06:21 PM   #166
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
Must just get the right offset it stick to much out.
And for the bushes you mentioned it one off the post and did some research
Agreed offset is your issue. Those rims don't look right for an Mkiv Supra (jza80 chassis). The oem offset is +50mm for 9.5" width rear rims. The oem rear rubber&rims have more than a full inch of clearance on both the inside (to the shock&spring) and the outside (to a rolled/trimmed fender lip), so a +50mm offset is still correct for an 11.5" width rim. When I widened my oem rear 9.5" rims to 11.5", they added the 2" of width on the inside, so I used a 1" hub-centric spacer to restore the +50mm offset.
Life begins at 30psi.
