That stuff is always a personal preference thing. If you want to try it then you probably need to find a place that sells custom headlight buckets and then fabricate the mounting stuff. With the small headlights that some cars have today you might be able to find something at the junkyard, but it will take some work and it is hard to undo things sometimes.
Good luck with it though and let us know how it works out.
Russ
