Originally Posted by cre
I'd start with suspension and brake upgrades, then start collecting parts. Some things such as a fuel controller, wideband controller, adjustable FPR and stronger fuel pump may all be installed while still running the N/A and it will give you a chance to learn the fuel controller. You can also install a good oil cooling system on the GE which will still be used on the GTE.
yeah i was looking at an oil cooler.
http://compare.ebay.com/like/1405586...Types&var=sbar
im going to be doing suspension, brakes and tires here very soon.
tires first! i am beyond the legal limit of tread on tires.. i believe 4/32 in california is illegal
i trying to get a decent idea of suspension though. im looking around and just dont know what to get. maybe you can give suspension ideas.
BTW - i have code 12, 27, 41.. i cleaned the ground strap terminal on the intake manifold and put it my extra ecu and it cleared up. i havent drove it yet to see if theyll come back yet. but i know that dirty or corroded ecu ground straps can throw codes.
