No, you would need a standalone. Even if the fuel controller were capable of pulling that much fuel the modified data the ECU receives will cause the fuel map to shift (mostly correctable with the piggyback) and the timing map will shift significantly. There may be additional issues that I'm not thinking of at the moment.
