Is it difficult to turn the wheel regardless of RPM, or is it only difficult at idle? If only at idle/low RPM, check that the vacuum line running from the accordion hose (after the AFM) to the power steering pump is attached. I've found that tends to be overlooked during reassembly of the intake piping.
