Originally Posted by supraguy84
i can get it started , but its definitely running way rich, pull the brand new plugs and they are wet, runs great when started. coolant temp sensor? cold start injector? input appreciated so much guys. thankyou
Hi! - Ok . so the engine starts now , Question: , How long are you running the engine ? -long enough to get the thermostat to open ? . When the engine is warmed up from cold , the mixture should weaken and run smoothly ( this may take a few minutes ! ) . The plugs should then be a brownish colour , Black ( sooty ) plugs are a sign of richness , white plugs are too weak , more feedback info please .
