Oil burning could also be from the BHG & to be honest likely is just that if it didn't smoke before.
If it was smoking anyway, valve guides/stem seals usually cause a puff of smoke on startup & a little trail while decelerating from high revs on closed throttle, bores/rings (or turbo seals don't forget, puddles in your intercooler & 3000 pipe?) would be more likely to cause more constant smoke even when accelerating or running for a while.
