Just be aware that both TSRM & Haynes have some glaring omissions & errors in torque specs (the main one being the head bolts which are specced as 58lb/ft but should really be more like 75lb/ft IIRC)
Also if the Haynes is anything like all the others I've read as a kid learing my hobby (it will be, they never seem to change!) then it will have other errors that could potentially kill you or others (like the Austin Allegro one with backwards brake M/C seals  ) so anything you're not sure of or is contradicted by the TSRM you're best checking up first before believing either one of them
