Originally Posted by Travis89Turbo
Problem resolved it is back to running great again.
Some how my cam gear bolt came loose and the cam slid just enough to retard the timing like crazy. I know the bolts were torqued to spec but this time I put some loctite on both of them and over torqued by 5 ft pounds. All is great now!
Wow - strange problem. If you don't mind me asking, what is 'spec' on the cam gear bolts? Since all adjustable cam gears are aftermarket, I'd guess those specs vary from manufacturer to manufacturer?
Either way, I'm really glad to hear you found the problem. Many thanks for keeping us updated!
