Originally Posted by pwpanas
Just curious: has the sound it makes while starting changed at all since before the problem when your brother borrowed it?
No it didn't it just losses its idle then it would stall the car
Originally Posted by cre
It's quite uncommon BUT... If the drive gear, pinion or fork in the starter were damaged preventing the drive gear from disengaging then yes, the starter could be the source of the problem. Your idle would bog (it'll get worse as the starter decays from the abuse), you'll have difficulty starting the car and you may experience electrical problems.
So whats the best way to fix this problem?
thanks for replying btw
