Thanks CRE. that will be my next section of the motor to work on. I am presently removing the whole intake (from the throttle body to the block) and using carb cleaner to clean all the sludge/gum from the bad gas that had been sitting in it. I do have a question on the N/A; if air were forced into the intake/throttle body, what would happen to the performance? would it increase the power (using cooler air from the front of the vehicle, not the warmer, under-the-hood air) or just the gas consumption? If it would increase the performance, I have an idea....
