Originally Posted by sniper_555
thanks guys for your response the ecu is tuned for an na my car is na if i turbocharge it will it work
Most likely not.
If your ecu measures air via pressure (aka "a MAP sensor") then that ecu probably won't know what to do with positive pressure...since an n/a engine rarely produces that condition.
If your ecu measures air via airflow (aka "MAF"), then it's *possible* your ecu will know what to do with the extra air getting pushed into the engine with the turbo...but only until you run out of fuel. However, you can't *only* upgrade your injectors to ensure you don't run out of fuel, because then your ecu will squirt too much fuel under all conditions. Together with a simple fuel controller (like an A'PEXi S-AFC), this might work.
Oh, I'd be remiss if I failed to mention (as I have in other threads) that slapping a turbo on an n/a Mkiv does NOT result in anything close to the car you'd get if you started with a TT to begin with. Brake rotors, calipers, ABS ecu, engine, ignition, suspension, transmission, differential, etc., etc., etc. are all MUCH, MUCH better in the Mkiv TT. If you really want to end up with a car that has all of the capabilities of the Mkiv TT, you will NOT get anything even remotely close by putting a turbo on an n/a. It's FAR cheaper to sell your n/a and buy a TT, if that's what you really want.
Other members of the forum please feel free to contribute here...I've never owned an n/a Supra, so it's not my area of expertise.
