Thread: Engine Help!
Old 10-20-2005, 12:49 AM   #4
Burn N' Up
Burn N' Up's Avatar
Are you losing radiator fluid? Is there even 50/50 in there and not just straight water? Is your water pump putting out the right pressure or fluid at volume? How is your timing? Lots of things can cause overheating my friend. There are alot of cheaper things to fix than going right into the MHG+studs... unless you were going there anyways. Is it AT or manual? Is your radiator full of all kinds of gunk? Tried flushing and refilling the system? Are you burning any oil? Black or white smoke form the car when your going down the road? If so is it foot on the gas or off? I'd do a bit more trouble shooting before an engine rebuild.
