Old 05-08-2013, 02:53 AM   #3
Bru
Bone Stock w Upgrades ;-)
Bru's Avatar
Check fuses espcially the EFI fuse. After that take out the front spark plug and ground the body of the plug while someone cranks the engine to check for spark jumping at the electrode (wear rubber gloves). The service manual has a diagnostic scheme to follow. The fuel pump can be checked for flow by jumpering Fp and B+ with a thin wire or paper clip in the diagnostic block with the ignition on. You sholud hear fuel flowing near the pressure regulator on the fuel rail. Check for error codes from the car's computer.
