TSRM says 22 is the CTS and 11 does not exist (not listed as a code). Don't know what source you checked from but the TSRM is the one to use... But you need to check the trans codes as per cre's link anyhow.
I'd lay odds on a speed sensor fault (42 or 61) as it only occurs when moving. Perhaps the wiring plug got wet or knocked loose but the code will at least give you an idea where to look closer
