Originally Posted by cre
Try again.... those aren't transmission diagnostic codes. Did you follow the link I posted?
As for the code 11 and/or 22: What good will it do to ignore the ECU codes? Something IS ovbiously wrong or they wouldn't be present. You may reset them to see if they're old codes for things which may have been fixed in the past but it's not too likely.
Im gonna run a diagnostic again to see if im still getting an ecu code. Everything is working fine now so I think its an old code from when I did the rebuild.
1989 na turbo supra ~ 3ARacing exhaust 2.5" pipe no resinator, sports package
