Old 06-05-2013, 02:48 PM   #1
Sturbo
Sturbo is on a distinguished road
Default The question of the the correct removal of EGR
If you simply remove the EGR system from the car, but do not disable it in the ECM, you will run into significant problems. You will likely run into detonation, the engine will run very poorly, lack power, and will probably run on the hot side as well. In addition, you will get a code 32 before running very long. If you recall from before, the ECM alters fuel and spark advance when it thinks EGR should be on. If no EGR flow is possible because you removed it, you will have a lean condition which will be further aggravated by advanced timing.
who removed in ECU?
Sturbo is offline   Reply With Quote
