The easiest route is to just disable the alarm system by bypassing one of the switches on the back of one of the lock cylinders or remove a sensor to one of the door sensors or the hood or trunk alarm sensor. The second would be to leave the system functional and replace the worn out sensor on the back of the lock cylinders. The third would be to remove the system and the fourth would be to add a modern security system with OEM alarm integration functionality.
