Thread: Smokey turbo
Old 06-07-2013, 02:43 PM   #2
MA70-3.0GT
MA70-3.0GT's Avatar
You say there's smoke from under the bonnet too, particularly from the turbo area? Have you pulled the turbo intake & bottom intercooler hoses off to check for oil there?
Provided your compression test comes out good I'd suggest perhaps it's failed oil seals on the turbo, this would be confirmed by oil pouring out of the intercooler when you pop the hose off & you can check the turbo bearings with the intake pipe off, there should be minimal play there (barely noticeable at all)
