Originally Posted by CanadianBak'inSupra
Well first off if your motor turns over its not your starter.
I'm going to assume fuel. So First check your error codes, second check for spark. If you have spark test your afm it's either that your pump relay or the pump itself.
i checked the error codes but found nothing on it blinking nonstop so i assume nothing is wrong with the electrical? and how can i find the fuel line my manual isnt very descriptive its more for someone who is experienced. also the cold start i njector had a drop of fuel in it but after that one drip there was no more.
