is any one running a full throttle gen 2?
so bought a gen 2 to help get around the bad afm I had and its wired up but there is little to no info on this unit. all the info I found is on the maft pro or just the basic translator. I called full throttle and they basicly said "it takes 15 mins to install and tune you'll be fine" that's there response to me when asked if they had more usefull info on the fourms
if any one has one installed or has any usefull info could you please let me know
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
