Old 06-25-2013, 06:47 AM   #10
btwilson86
Super Moderator
btwilson86's Avatar
You're right, you probably can't return it, so you'll have to eat the cost and buy an appropriate sized gasket. From what I've read, these engines are quite picky about combustion chamber size, so if you run your current gasket you're setting yourself up for failure.
You have opinions/experiences from knowledgeable Supra community members (see thread referenced earlier), and they're saying the build you're proposing is far from ideal. To me, it's a no-brainer; spend the couple hundred bucks now so you don't have to spend the couple thousand later.
