Alright so I have .4318mm off the head, .1524mm off the block. Stock gasket is 1.37mm. So adding that up the gasket would have to be 1.9542mm. You really think I can't get away with a 1.4mm MHG? Just clarifying here cause a 2.0mm MHG would roughly be another 185 bucks. Then I have a 1.4mm gasket laying around.
1988 7M-GTE Manual Turbo, Godspeed IC, Stock HG Torque to 90FP W/ Arp bolts, Silicon water hose kit, silicon vacuum hoses, Godspeed radiator, 2 12" electric fans.
