Old 07-31-2013, 01:29 PM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Not every turbo had a MA71 VIN code, I've had a factory turbo with a MA70 VIN. There is a plate under the hood on the firewall on the drivers' side. This gives you some key codes, such as what engine, transmission, and differential came in the car (see this link here). If this is a factory turbo car, it should say 7MGTE for the engine, and then either R154 (standard) or A340E (automatic) for the transmission. Hope this gets you going, and good luck with the car
Oh yeah, the boost gauge is on the right of the gauge cluster, next to oil pressure and fuel
