Thanks, but I'm quite sure this is not a battery issue; I suspect a relay or fuse blew or this is something with regards to the theft system. There is no power inside the car and I heard a clicking noise when I tried to start it. Now there is still no power and I hear a faint siren type of noise whenever I put the key in.
So, what would cause this faint noise whenever the key is in (but not turned on) and would explain the lack of power to the inside of the car?
EDIT: I went to try your advice (what did I have to lose?) and the power inside the car was back on, which then led me to believe you were right.. and you were! Thank you! Apparently the last time I drove the car was longer ago than I thought.
