Originally Posted by Bill UK
Not sure but I think the oil sump is also bolted to the bottom of the rear timing case. At the time I was doing a total engine build so the sump was already removed.
Yes, it is. This isn't something you want to remove with the head in place either... just in case someone thinks it's possible. (It is but it's a horror story and there are modifications and sacrifices which must then be made.)
