I didn't do the rewire myself a shop here locally did it. It's the second time they have done the rewire. Once with the original harness (problem was solved). Then I had this used auto harness swapped on the car and the code 52 came back so I had them do the rewire a second time, as well as check the actual sensors again. the problem is still here the only reason i said the sensors could be jdm and usdm is because one is original to the engine and one is not. For all I know they are the same.
I mostly wanted to see if anybody has had this problem and if a jdm engine needs a jdm ecu?
Also, why am I having such a hard time getting rid of this code 52? All the tsrm procedures have been performed by myself as well as other more qualified mechanics, but to no avail.
Anyone who has never made a mistake has never tried anything new.
