Just about anything with a higher capacity, lower restriction and more surface area is going to be a worthwhile upgrade. Don't spend too much time on this particular item, just get a well known brand. On a 7M-GE (or even a mildly built 7M-GTE) you're not going see a huge difference from one to the next. I've run the Koyo 1JZ radiator on a turbo'd 7M-GE (N/A-T) and a 7M-GTE and was very happy with the performance. They fit very well but you have to make two little brackets to clip the bottom of the fan cowl into and get a plug for the extra coolant sensor port on the bottom. They're inexpensive too... At least they were the last time I bought one.
