Originally Posted by S-mk3-B
So as for the swap, i do know that there are a couple of things you will have to do. Some being a 7mgte ecu, r154 trans, maybe the driveshaft as well, an intercooler system; cause you are going turbo now, maybe fuel pump cause the 7mgte will need a more efficient way of obtaining fuel, and I'm sure there's a lot more.
Hope this helps!
Thank you for all this information, I have a question though. I have the stock 4-speed automatic, will it be necessary for me to replace this with the r154? This is actually my biggest concern. The engine im buying has the intercooler with it.
Also, the cc is the same for both engines, but will the 7GMTE require different mounts? Or will it essentially drop right in the old space. Also, would it be to my advantage to look into a better radiator? It is original stock as well.
