If the valve is leaking you could bypass it and give up having a heater or bypass it so that the heat is always on. I don't think either will make you very comfortable in the long run. I would try to find a used valve for replacement. The valves don't seen to fail very often, it's the connected VSV which controls it that usually fails.
