Old 10-26-2013, 04:24 PM   #1
warmkop
Moderator
warmkop's Avatar
warmkop is on a distinguished road
Default 2jzgte not making power...?
Hi everyone.
I need advise we installed a 2jzgte motor in an e46 M3 but it's not making power as soon as it gets to 5800 RPM the power drops.
List of mods done.
Running a powermod ecu
Stock bottom..gasflowed head,cams cut same place as mine split duration 268 ex and 272 intake.
Turbo T72 .68 Exh Turbonetics. Same Exh manifold as mine cheap.
Turbosmart wastage 45mm..
50 mm dump valve.
Fake Greddy intake manifold.80mm throttle.
750cc injectors.
Cometic low comp gasket with arp studs.
76mm downpipe with 76mm Exh.
It made like 240kw and 400nm something is wrong....?????????
warmkop is offline   Reply With Quote
