Originally Posted by warmkop
I everyone.
So update on the car is had trouble with the turbo leaking oil out in front and the back had the seals replaced on my new turbo and it was okay did like 2 events and a dyno and now the turbo is starting again o and it smokes between gears changes dont know why it keeps doing it.
But its in to get the luanch controll connected up and to set the boost up if the turbo is going to handle it.lol
A few questions:
1) Are you using 100% pure synthetic oil on all of your oil changes?
2) Do you have an
oil filter installed in the oil line feeding the turbo?
3) Do you have a
restrictor installed in the oil line feeding the turbo? (Note that HKS turbos come with a
restrictor built into the oil line fitting on the top of the turbo.
http://www.turbobygarrett.com/turbob...oil_restrictor
