Old 10-31-2013, 06:58 PM   #175
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
I just changed the oil it had synthetic oil in changed it to semi synthetic because I change the oil about every 3 months.
No I don't have a filter.
It has a 3mm restrictor in.
Recommend you change back to full synthetic. The temperature of your turbo(s) break down non-synthetic oil, no matter how often you change it.
3mm is quite large - you may wish to consider a smaller diameter restrictor and an oil filter in your turbo's oil feed line. The smaller restrictor may fix your turbo oil seal leaks, and the filter will help keep the restrictor from getting blocked by random debris (or particles of coked non-synthetic oil) that may end up in your crankcase. This restrictor has a .04" (1.016 mm) oil passage:
http://www.frsport.com/Turbo-Oil-Res...FQto7Aod-iwA-w
A 1mm restriction has 0.785 sq. mm. area, and a 3mm restriction has a 7.065 sq. mm area (9 times greater). Although I'm not a fluid dynamics engineer, I'm sure a hole that's 9 times bigger will flow quite a bit more oil...
Life begins at 30psi.
