Old 11-06-2013, 11:20 AM   #177
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
I need advise on launch control we can't get the chip to read the crank signal black/red wire any advise..
I assume everything is running fine other than the launch control.
Are you using the oem crank signal, or have you equipped the harmonic dampener with a secondary (eg. hall effect) magnet & sensor?
Life begins at 30psi.
