What are you trying to accomplish? In the Lexus AFM mod it's the housing that's different. It uses the same sensor as the one in the Supra's housing. Bigger housing = more air = needs more fuel... This mod and it's requirements are well covered on the forum already.
I forgot to mention this: If you've got a bad sensor and you're just trying to get the car back to running in stock form then yes, all you use it the sensor and put it in the Supra's stock housing... No bigger injectors or anything.
