Old 11-10-2013, 12:29 PM   #179
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by warmkop View Post
Everything is running fine.
Using oem crank signal.
If your aftermarket traction control system can't read the oem 2jz-gte crank signal, you may need to use an aftermarket crank signal.
When I was running my Haltech E6K, this was a required modification.
Check out the link in my last post (above), and let me know if you have any questions.
Life begins at 30psi.
