7m's drift well, but problem being that the turbo is quite laggy, so power drifting is difficult. can be done though, just keep that side of things in mind. 1g's i don't see why they wouldn't do it well, good responce from the twin turbo setup, just a bit low on power, so up the power by a few psi, and should be good. 1jz's would be the best option really, but in saying that the rest are fine if tuned and know about their weaknesses. a 3sgte in my mind would be worthless in a mk3. good strong motor's, just not suited to the weight of a mk3, you would have to get stupid amounts of power out of it, and even then it won't be that good due to the delivery of the motor. if your getting that idea from the mk4 that runs a 3s, that motor is barely counted as a 3s. extensively redesigned.
hope that helps
